Found some nice sending unit adaptors today
moparmat2000
Grand Tetons
Went to the boneyard today. Had a few wants I wanted to get. While I was pulling a distributor from a late 70s early 80s 360 ram van I noticed a nice tee coming off the oil sender port in the block. It had the gage sender mounted in the 45° angle part of the tee, and some sort of 3 prong pressure switch mounted in the 90° part. I grabbed 2 of these today. I figure these are perfect for when you want your stock electric oil pressure gage hooked up, but still want to run a mechanical one under the dash. Factory stuff, all the right threads, and you wont have to make it out of miscellaneous hardware store crap. I am keeping these for my projects, however it gives you an idea of what you might just find when looking at ram vans and pickups.
