Ok so mini milestone finally getting the 8 3/4 hooked up. Encountered a problem with shackles flipping inward instead of outward. I'm doing this on my own so a bit of a struggle.
Springs are factory but re-arched years ago. Looks like both front and rear hangers are on correct.
Tires are only 13" rollers.
Large bolt for front spring eye is loose.
Shackle nuts are finger tight.
Undid bottom of 1 shock to make sure it wasnt the issue.
Shackle is close but not quite.
Both sides are causing me grief.
Currently no jack stands, tires are sitting on blocks of wood to lift rear up.
ATV jack under the diff but not supporting it. Figured I'd let it sit overnight to see if it drops any?
Pics are if drivers side.
Suggestions?
Thanks
Steve
Suggestions?
Thanks
Steve
