[Found!] Windshield Washer Reservoir for 65 Dart 270
1970Dart340Swinger
Active Member
Live Free or Die
Rating - 0%
0   0   0
Would love to find one of these...mine is cracked and has a hole.
Thank you!
I believe they are being reproduced. I’ve heard that the distance between the mounting ears is different than original tanks
I have one but not sure if it is nos, oem or a repop. Here are the stamping on it capacity 62 oz, part no. 2497502, has the pentastar logo with chrysler cooperation. The lid has washer fluid only on it and the numbers on the back are 3449 lot 1, ms-05-24, 2497502. The tab to tab width is right at 9.5 inches and center to center is just about 8.75. PM me if you are interested.
Repop.
Repop. The lid should hinge on the same end as the nipple on this year. (like the original.)
Wait, that wasn't right. It was that way on my 70. May be they got this one right. Sorry, my bad. I didn't pay close enough attention.
I have an original. It's cracked and has a hole also. I bought a reproduction which is close several years back. By close I mean it will work and fool anybody who doesn't know the difference. The bolt holes, cap and color are slightly different.
Also the "doghouse" pump on the inner fender was used by Fords of the same vintage so don't pay too much from some Mopar vendors https://www.cjponyparts.com/acp-windshield-washer-pump-1-speed-3-bolt-1965/p/WWP1/
Measurements are the same as my original, but numbers on the back are different and my cap is blank. I think I read somewhere that the original caps were blank. However, I am still interested. Is there a pump that goes with this?
Numbers/letters on back of mine:
AATK
2497502
MS DB 24
Lot 60
11285
