C2ndLTpigeon
Mopar or no Car!
Wanted to see if anyone knows where I can find something to use as guide pins to install a ring gear on my 8.25 carrier. Left handed fine tread.
Thanks
Thanks
Set the ring gear on the carrier loose and start two bolts.Wanted to see if anyone knows where I can find something to use as guide pins to install a ring gear on my 8.25 carrier. Left handed fine tread.
Thanks
Then tap the ring in place and add the rest of the bolts.
I’ve never needed them.
