1967 Copper interior parts
Oops, darn thumbs anyway!
Have you guys looked at the interior colors and combos shown in the HH info for 67 Darts, Valiants and Barracudas?
It shows the dark brown under the Tan interior examples for two of the Valiant options. Clearly some Barracudas also got dark brown with tan. I'm not so sure about Darts or the Copper interiors.
67 Dart my carpet was the dark brown.
Here's the tag of my original-to-the-car carpet. The darkest aftermarket carpet was still lighter than the original, faded stuff that came in my car..."Chestnut" was what they called it, "1967 Val B/S" ...because A-bodys with bench front seats came with "Valiant" carpet sets. You can also see the date code stamped on the tag..."Jan 2 1967"
Do you guys know what color interior this is? I don't know if my monitor is just off or if I'm colorblind. It's shown at 47 seconds and is shown off and on after that.
This is exactly the same combo my car is. It’s HH1 dark copper metallic paint with copper interior. Thanks for the video I have never seen another barracuda that combo.
Ah ok... I misunderstood. I thought you had painted the underhood and were going to paint the car that color.
Yeah the engine bay color is the correct color that will be covered on the rest of the car
Hows it going?
Eh does anyone know the paintcode for the Chesnut flat dash, column etc color?
I am redoing a '67 Barracuda that is Med Copper, with copper interior, brown carpet, console, dash etc.
Also where is the best place to get the darkest brown carpet from?
I need to order a brown headliner too.
Cheers!
-Shiny
This might help, I think the Copper Brown is actually the color used with the Copper interior.
Alan
Maybe the links and info in this post will be of some help.
I'll paste some that post here below. The 1967 Dodge Shop manual has more paint info than the Plymouth.
The final key to the puzzle is figuring out which colors go with the interior color name on multi color interiors
Using my '67 Plymouth Barracuda for example. Fender Tag Code SS4YY
Y is Tan interior.
By cross referencing PPG 22700, this is what the Dodge FSM calls Pale Tan, and may also be called Medium Tan or Light Tan by others.
So that gets the basic color.
Then the challenge is figuring out which colors are used on the other components.
[For my car's "tan" interior,] my guess is that "chestnut" for the metal dash because its close in color to the dashpad and carpet and the carpet was chestnut. At this point it will be probably best to have sample chips to check against the car as it also could be Copper Brown.
Finally note the finish for varies depending on what its used on.
