[Found!] Accel 140306
How about a new Mallory 28880 coil? Still wrapped in plastic. I must be 35-40 years old.
I have a NOS chrome Accel super stock coil. How much would you want it for? It's just the newer part number of the same coil you requested.
I have a Mopar chrome coil that is supposed to be used only with the gold box. I'll dig it up here in a bit and see if it has a number on it.
If its the Direct Connection made by Accel for Chrysler it will work also they are a little bigger in diameter but thats ok I have the proper coil bracket also !
This was a coil a friend used shortly on a dirt car. He bought it new through Mopar Performance. I have no documents on this. I used it shortly on my mud racer back in the day. It functioned perfectly. However, tach went nuts with this one. I think this is intended for a mechanical tach. I can rig it on my engine run stand to verify it still works. PM me if interested.
View attachment 1715628835 View attachment 1715628836 View attachment 1715628837
Yes
Interested
FWIW, when I received my TD distributor kit and coil way back, the 140306 was the replacement coil for P3690560. At least that's what Koller Dodge told me.
Found my new one that I bought for my gold box but never used. Little dusty from sitting is all. I would take $50.00 plus actual shipping if you are interested.
