72DMag
Hi Looking for fuel pump and filter recommendations for a 360 in an abody with a 750cfm e85 carb that has 11.5:1 compression. It's for drag racing mostly. Thanks
I always run a return line on everything. Kim@oldkimmer That does make sense to keep the fuel from boiling but with ethanol I doubt it would have any effect. Maye for a street car that sees low grade 87 fuel this would be beneficial.
