72 duster MSD
mummertj
Manassas VA
have a 72 duster and have installed a Mallory distributor and MSD 6AL box
Currently the car doesn’t have a ballast resistor and if I wire both red ( big red and little red) together to the battery all works great except I can’t shut it off ( I temporarily installed a toggle switch) but if I hook little red wire up to 12 volt switched, when cranking power drops to low to start it. Need some help where can I pull power from to run MSD while on the key switch
I used the wires that went to the ballast went thru a terminal strip. the terminal strip I jumped a couple of terminals as to have voltage for the functions, start, run, MSD.
Where can I find these wires? the ballast resistor has been taken out, what color are they ? I hate so sound so simple which firewall harness do the come out of passenger side drivers side or middle
Thanks
Do you have a service manual?? The wires should be close to where the ballast was mounted.
This question comes up on this board about once a week. The "run" wire, usually dark blue, IGN1, GOES DEAD during cranking
There is a second wire, usually brown, IGN2, which is the ballast bypass circuit for starting. It is hot in "start." It is NOT however, the same as the start wire, but rather a separate circuit
It originally connected to the ballast at the coil side. You must jumper IGN1 and IGN2 together and connect them to your small red MSD wire
NEVER connect the large and small red together. The big black and the big red must be to a good ground and to battery "hot"
Also, never leave ANYTHING connected to the coil EXCEPT the two MSD wires. Disconnect tach or radio condenser or anything else. ONLY the MSD wires are to be connected to the coil
