Magnet head
"One piece of advice though...... close your mouth when crawling under vehicles."
Same thing goes for weed whacking the dog lot! :eek::D
Stop by an appliance store, and ask them if you can have a refrigerator box out of their cardboard dumpster. You can use that on the ground when you crawl underneath a vehicle, and it will keep you cleaner and keep the hitchhikers out of your hair.
I use hot water heater boxes , exclusively ------------big, w/ the ends cut off , heavy and thick double layer when folded flat !
Ditto while grinding....goes without saying. Sometimes you gotta look right at the sparks from your grinder due to angle. I wear a welding helmet without the tinted glass down for that. Had an oxide chunk in my cornea, had to get driven to optometrist and she got it out with a Q-tip after an eyedrop was given to me to dull it. She rolled it against the direction she was going across the cornea so it would pick the piece and pull it out instead of pushing it or further planting it into the eye. Instant gratification! Sent her a Christmas card that year.
Gee! The old long hair getting tangled in the creeper wheels trick. I had almost forgotten about that. Seeing I am past 65 now that is a distant memory.
So I have a theory that your eyes are actually magnetic and your hair is an attractant to non magnetic debris.
I find it odd that everytime i crawl under a car, even when it seems clean and clear enough..... all the grease chunks, random rust flakes, and metallic debris goes straight for my eyes. My hair seems to find and collect all the unseen dried thorny plant remnants, leaves, and grease chunks.
Hmmmm what is with that.
Know what you are talking about for me it’s acoustic sealant. I don’t even have to open the tube just look at it and I’m covered in that black crap
I bet you always Park on a hill so you can start that car seeing as how there's no starter
