oliver
I was digging though my stash of cams for a spare parts build and found an odd one. I could visually tell the lobes had quite a bit of lift so I didn't even bother but I did throw it in the v blocks to get some specs on it.
Looks like it's a 250/245 duration at .050" tried to get duration at .012" and got 295/305 which is whacked but I got repeat results on multiple lobes. Lobe lift is .375/.345 which would be .550/.500 at the valve with lash as this is definitely a solid flat tappet. LSA is only 104!!!! I did not do the valve timing as I didn't want to spend too much time on it.
I almost want to slap it in my 340 with a set of hydraulic lifters and let it rip on stock rockers. Haha. But seriously, what the heck would this even be good for? 5500-6500rpm power band with a good exhaust system?
