Sway Bar ID needed.
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
I have 2 sway bars that I think but need verification that they are for A bodies.
They measure 44 1/2" eye to eye at the link hole. Am I correct on thinking these are A body bars.
@George Jets
I pulled a sway bar off a 75 duster and it had that flat bar like that top sway bar.
Real close to the link in post #2. We need a depth measurement, 90* to the centerline.
I went out and got some better measurements. Eye to eye is 44.5 & 15.5 over all depth. Bar is 15/16" dia..
I orginally said 44inches eye to eye. That's not the case.
'73-76 a-body sway bars are straight across the front . '67-72 sway bars have a hump in them for the valance support . I think '69/70 b-body bars are the same . 2 different dimeters were used . I'm not sure but I think they were 3/4" & 7/8".
The B body bars are 15/16" up to '69. My 72 A body bar is 7/8" I can't post a measurement because it's bent - got it that way. :(
Ok I measured as best I could since it is on the car. Eye to eye it is 44-44 1/2”. It is about 14” deep.
