WANTED! WANTED! ASAP
I knew you guys would know thanks "pishta" I'll order one tomorrow. A set of bare aluminum heads will work.
Then you could rent it out or flip it after your done. Super handy when setting up motor mounts! They got bolt bosses too for accessories. They even have a few intakes in their catalog.
If for some reason you can't get that new one right away, I have one you can borrow.
This is what I ordered today. The total with shipping was $510.19 . I got the W-2 bolt on heads with the block. I also gave Dale some info on the difference in the 273 318 340 and 360 block. They are going to make changes after sending these pictures
https://mockupmotors.com/shop-now/ols/products/chrysler-318-w-heads
