[Found!] WTB Super Six Kickdown linkage and cable
Jax_1975_Dart
Jacksonville, Florida
1/14/2021 [Found] Need to mark this as closed thread.
I’ve been reading that these are scarce but, figured I’d put out some feelers amongst my fellow A body enthusiasts.
As the title states: I’m looking for the automatic kickdown linkage and accelerator cable for a Super six setup. The vehicle is a ‘75 Dart Sport 225 and will be using a Carter BBD 2 bbl with this new to me setup.
Thanks!
@halfafish Hey, it was recently brought up that you had one for sale in November. Please let me know if it’s still available. I also replied to your thread on the Slant Six dot org forums. Thank you!
Sorry, it was sold several weeks ago. I wish I had a dozen of these, I could have helped out a whole bunch more people.
Would the set up off a 1972 dart swinger work for you? I’m doing a V8 swap on mine and just removed all of drive train and brackets as I had to get all the stuff for a 340 and 727
Was it a Super Six installed on there previously? Any chance you can post a pic? I’ll try to upload a photo of precisely the hardware I need. But, a photo would quickly clear up if it will work. Thank you!
You might sign up at slantsix.org and ask there if someone has the levers. It's an excellent resource site for all things slant related anyway,
Update: Found the kickdown rod and curved carb linkage. Now I need the throttle bracket. Will mostly mark this as “closed” or “sold” and open a new thread for just the throttle mounting bracket.
