67fish383S
Came out of a '68 Barracuda. Has the clip-on cable connector (not threaded). If you have the earlier threaded connector, you will need to swap the cable. Does not have the trip meter. It worked well when removed from the car.
$125 picked up or plus shipping from Spring Lake, MI 49456. Will fit in a medium flat rate box ($15.05). Alternate contact: 2ndgenbarracudaparts@gmail.com
