- Joined
- Sep 2, 2008
- Messages
- 262
- Reaction score
- 112
Working on my Demon, about to be ready to drop in engine/trans.
Looking for what spark plugs, oil, and trans fluid to use.
I know this is a lot, but I might as well throw it all in one thread.
‘72 Demon all steel....owned it since I was 15 (1983) glass hood, stock interior.
360, .30 over 4.125 stroke crank (420 cubes)
Eddy heads, Hughes stage 2 porting, super victor gasket matched, 820 Holley.
10.5:1 Comp. Bullet hyd roller cam .249/257 @ .050 .573 lift.
904 trans, rev. valve body, PTC 3800-4000 rpm stall converter.
4.30 gear, 275/60-15 Drag radial.
When I raced the car years ago, it ran 12.20’s with hydraulic cam, and a B&M Super Holeshot converter, and 9x28 slicks.
Technology has come a long way with Cams, converters etc....
That’s why I’m asking you guys here that are “In the know” and up to date with everything.
Mainly what spark plug is good, oil and trans fluid.
Is the synthetic good?
I know this is a bit long, I sure do appreciate the help all!
Wally.
Wally.
