msd hemi 6?
71scamp78
terre haute indiana
Is anyone here running the msd hemi 6 . Just wondering if you are happy with it. Im on the fence about the hemi swap and if I do it I will use a carb not fuel injection. What intake and carb combo. Does it run and perform.well with the msd 6. Thanks in advance.
I had run it and a modman intake, 650 vs carb. The combo ran very well but the intake design wasn't the best. Switched back to EFi and picked up 3 mph in the 1/4. I made a timing curve for the msd that worked well. I would recommend the OCP intake if your staying carb.
Ok sounds good and I was gonna use an OCP intake. Was the msd easy to mess with as far as getting the timing right and tuned.
Yes, but there are some settings to turn off on the MSD. If you decide to do this I can send you a timing curve and show you what to turn off
Sounds good it may be a bit waiting on machine shop if my engine is good for a build. If so it won't be to long before it's together. But then I have to do some brake and some suspension work. I will pm you and get your email if that's ok
I did a swap in my 70 Cuda back shortly after MSD came out with the Hemi 6. I am running a Mopar carb manifold with an Edelbrock 750 and the Hemi 6 controller. I like it and have never had any issues with it.
I've never messed with the factory timing curve or anything else. I would be interested in hearing more about what you turned off and how you benefited from changing your timing curve.
Ok I gonna build stroker I believe. 345 to 392ish . Question is will the Hemi 6 work with it as well. I tried to call Holley tech line and got no one. I know I will need the 32 tooth crank wheel already but curious if it works with a stroker
with the 32 tooth wheel it should, there might be a different pig taill on some of the conectors but that is easily fixed
