7Duster6
New Member
Im needing help;I just took the 318 out of my 1976 duster and I'm looking to stick a 383 in it but i have no clue on and parts or procedures for fitment I'm just wanting to stick in it and drive
You can't just "stick it in and drive".Im needing help;I just took the 318 out of my 1976 duster and I'm looking to stick a 383 in it but i have no clue on and parts or procedures for fitment I'm just wanting to stick in it and drive
they are also different size BB vs SB (IIRC)3.) Radiator. You may or may not need a different radiator, check your top & bottom inlet/outlets to make sure they will work with the 383. The inlets/outlets changed sides over the years and between big & small blocks.
Have you ever driven a potent big block A body. nothing like it.Did ya not read the thread about the small block cars wooping *** on the big block cars? Guess it depends on what ya want out of the car.
I’ll tell ya the 400 HP 340 in my 72 is perfect the ground pounding corner carving machine I built mine into. You dump the clutch at 3k, it just hooks and goes like stink...
If you're going to go to the trouble, at least go for the biggest big block. The 383 adds weight without really adding much cubes over a 360
383 with free flowing exhaust and 3.55 or lower gear is a different beast than any stock small block A-body.I'll take a 383 any day over a 360. Actually any small block over a 360...
Big block swap in an A body is old hat for me, It's really not that much more money if you're starting from scratch and rebuilding a 50 + year old drivetrain.
I don’t think I’ve ever seen a Sb kick a bb. KimDid ya not read the thread about the small block cars wooping *** on the big block cars? Guess it depends on what ya want out of the car.
Oh, we've HEARD lots of stories about that... seems to be rarely seen though
It's just that, a story............
