Mech Fuel Pump Drag Racing 318
Right on
@Darter6. I use one of the mighty mite style “click clack” pumps in line with the stock mechanical fuel pump. It’s worth about a half pound of extra fuel pressure at idle and and a little over a pound at 4,000 rpm. I’ve got it hardwired into a switch on the dash. You only have to run it when you think you need it. You’ll have plenty of fuel flow for your deal.
