@HemiDenny I bought these brackets from you years ago when you offered them. I am finally in the process of changing the radiator and water pump to a 70 from my stock 67 setup in my barracuda. Do you have part numbers, brands, whatever for the power steering pump and A/C compressor? I already bought CVF pulleys you recommended. Do you know if my stock alternator and power steering bracket and pump will work on the 1970 water pump with the hose on the passenger side? For now I am not ready to invest in doing full A/C setup (compressor, condensor, filter dryer, lines, etc.) but I want to put in the new radiator and water pump. If I need to buy the new PS pump and use your brackets to make it all work now, I will.
Any info you can share is appreciated!
