[SOLD] 1968-72 Dart Duster Valiant A/C Heat Climate Control Push Button Assembly W/Vacuum Lines
Part Stalker
East of Tacoma
See these have been in demand so I will put this up as it rarely gets warm enough for AC here. These were pulled out of a 69 Valiant but should fit other A bodies of the same era. Unit is complete and appears to be in good shape other than it needing a better cleaning or detailing. Buttons are stuck and I didn't want to force them as I am not sure if it needs vacuum to work. May just need a little lube. Temperature lever moves freely as does the fan switch. Bezel is in nice shape other than the chrome. Has all the vacuum lines and firewall grommet. The car still has some other AC components, but the Slant 6 is gone as with anything bolted to it. I would like $75 plus shipping from Puyallup WA.
