BARRACUDA340S
I sold the Pro Systems carb sun. I'm going back to BIGS. I talked to Jessie today and we were bouncing some ideas around between a 950 stage 7 and a 1050 dominator stage 7. Scotty loves his dominator from Jessie and Scotty's picky, so it's gotta be right. Jessie made me a no risk offer, if I don't like the dominator he'll switch me around to a 950. I would only have the added expense of throttle bracket and spacer adapter and base plate for air cleaner. Many guy's with the strokers said they picked up a 1/10th or better going to the dominator. Keep in mind I have a 4 speed car with 4.10's. Here is my set up
416 small block
12.4 comp
Indy 360-1 single plane intake
Indy 360-2 CNC'd heads
cam solid roller 254/266 621/624 112 lobe 108 center
TTI steps 1 5/8 to 1 3/4
x pipe exhaust
4 speed car wieght 3420 with driver
4.10 gear with 28" tire
chasis dyno numbers with a stock BG 1000 race demon
head flow numbers
head flow #s
.200 150.1/100.1
.300 210.5/146.6
.400 253.6/208.4
.450 278.4/226.0
.500 294.3/235.3
.550 310.2/244.3
.600 320.2/248.4
.650 329.8/255.3
.700 334.7/259.4
416 small block
12.4 comp
x pipe exhaust
head flow numbers
head flow #s
.200 150.1/100.1
.300 210.5/146.6
.400 253.6/208.4
.450 278.4/226.0
.500 294.3/235.3
.550 310.2/244.3
.600 320.2/248.4
.650 329.8/255.3
.700 334.7/259.4
