grimreaper
Cross Member
I kept encountering opposing opinions on whether the Green 8-3/4 axle bearing were suitable for street use. So I wrote to Bearing Technologies Ltd. to get the story directly from the source.
So here's the scoop:
The question is whether or not the RP400 bearing kit for Mopar 8-3/4" axles is suitable for street car applications. There has been a lot of discussion that since your catalog lists it under "Racing" that racing is the only application. Some have also said that the RP400 doesn't have enough lateral retention for street use. Others have said that they have several thousand miles of street use with the RP400s in their axles and have encountered no problem. Can you clear up the issue for me?
Dear XXXXXXXXX,
I received your question about the RP400. I'll try to answer this to the best of my ability. The original intent of the RP400 designed by the Green Bearing Company was meant as a replacement for the original taper bearings in the rear end of Chrysler / Mopar applications. It was made for street vehicles, as were all of Green's automotive bearings. Over time these products became favorites of custom axle manufacturers such as Moser Engineering, Strange Engineering and Mark Williams Enterprises. Green, being a job shop, manufactured a multitude of bearings for these outfits and started categorizing them as "Racing" bearings due to the fact that the products were becoming popular in that application.
There are a lot of these bearings on the road in both street applications as well as on track applications. As far as performance, all I can say is that these have been a staple in our product line with no revisions / issues for a long time. The experts on the performance of the product in various applications would be Moser or Strange. If you would like to contact them, you have to ask specifically for the RP400 with the fixed flange because there is a modified version (MO400) which was designed by request for Moser and has a slide over flange with a snap ring retainer.
You can visit www.moserengineering.com or call 260-726-6689 for more information.
Thank you for your interest in our products.
Best Regards,
Brian Graziadei
Bearing-Technologies LTD
Dear XXXXXXXXX,
Best Regards,
Brian Graziadei
