1966 Plymouth Valiant 100 sedan, 56,000 original miles.
1972 340, 650 Holley DP, Super sucker 1 inch carb spacer, Mopar M-1 single plane intake, 505 Isky cam, Rhoads lifters, Comp Cams push rods, Comp Cams aluminum roller rockers, stock 340 heads 2.02/1.60 Milodon valves, 1970 340 steel crank, stock rods, .30 speed Pro forged pistons. The rotating assembly has been balanced. Moroso deep oil pan, HV oil pump, stock windage tray, Hooker Super Comp fenderwall headers, 2 1/2 dual exhaust...
Log in or register now.
