1968 Plymouth Barracuda Formula S
68 Cuda Autocrosser
More info at:
http://hometown.aol.com/pwall5/cars/2cudapag.html
SUSPENSION
TORSION BARS: .99"
REAR SPRINGS: Stock Formula S
FRONT SWAY BAR: 1 1/8" Addco
REAR SWAY BAR: ¾" dia. Addco
SHOCKS: KYB These aren't good. Need QA1 or Koni
POLYGRAPHITE: sway bar, brake strut rods, lower control arms. Leaf bushings; can hear slight resonance when added to rear. Would not use LCA poly agian.
UPPER A-ARM BUSHINGS: offset, Moog prt.# 7103 installed for...
autoxcuda
Rating
3.50 star(s) 2 ratings
More from autoxcuda
