1969 Plymouth Barracuda Formula S 340
Installed an all new 414 small block stroker January 2009. Engine is a '71 340 block, .020" over bore, KB745 forged step dish pistons, Scat I-beam rods, and Scat cast steel 4" crank. Edelbrock Stage 2 Ported Heads milled to 62 cc for 10.3:1 compression by Shady Dell Speed. Crane springs installed at 1.85" with Crane 10 degree locks and retainers. Comp Cams Pro Magnum roller rockers. Cam is 586/540 lift, 236/242 @ 50 duration intake/exhaust 108 LSA custom ground retrofit hydraulic roller...
340sFastback
Rating
4.00 star(s) 1 ratings
