After seeing other non Mopar Garages I thought I'd toss this in. I did all the work except the long block and paint. The engine swap started with finding a used Muncie 4spd with the T case adapter on it. The first 350 was very stock and naturally aspirated, I used new available engine mounts and made my own for the bell housing and T case. I can tell you the T case and the front axle I haven't touched (other than new seals etc., and are bullet proof. If memory serves the front Birfield...
Log in or register now.
