1976 Dart sedan made in Brazil, mostly like the 1969's in USA with some improvements by factory from later models such as stock disk and power brakes, thicker T Bars Front sway bar, power steering, AC (Semco), all stock except for tires and wheels. 318 LA V8 (7.5x1 compression rate for bad gas) and 904 Torqueflite 3 speed non lock-up transmission 2,400 stall rpm, 3.15x1 rear axle, 14" wheels, AC, power steering, several components made in Brazil. Luxury model made from 1976 till 1978 only...
Log in or register now.
