390 hp. Magnum Crate engine. Thermo-block is bored .020 over. Magnum R/T Big Valve cylinder heads. Mopar cast Al. valve covers. High strength SS Valves, 2.02" Int., 1.62" Ex. Heavy duty valve springs. Hydraulic Roller Camshaft- 230'/234' Duration @ .050"/0.513" lift. pistons 9:1 C.R. Double Roller timing chain and sprockets. Mopar M1 black powder coated Single plane manifold w/650 Holly Double pumper. 150 hp. shot of NOS. Racing line lock, 3000 Huges rpm stall converter. Hughes racing...
Log in or register now.
