Low compression 400-4 barrel:
1. Stock bores - very little ridge and minimal taper.
2. Original cast crank, connecting rods, and pistons.
3. Original 452 heads, lapped original valves and seats. Green stripe 933 springs.
4. Old Direct Connection distributor. Mr. Gasket 925B spring. FBO limit plate set for 18* initial.
5.Carter AVS and cast 301 intake manifold.
6. Cam - Howards 227/235 480/488 hydraulic flat tappet with...
Log in or register now.
