´67 Dart Column Shift Linkage Bushings
CallMeAl
Active Member
Hamburg, Germany
Does somebody have an idea, where I can get
the bushings for the shift linkage ? I think these are 3 or 4 pieces - one of them a combination of rubber and metal. Mine are all worn and I have disassembled everything.
Thanks in advance,
Lars
I found all bushings except this one.
Can anybody give me a hint, where to get it ? It shows FK 252.
And for those who are interested, here´s my blog showing the restoration of my 67 Dodge Dart: http://translate.google.de/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2F67dodgedart.blogspot.com%2F
Looks like you have the rubber grommet. The only thing else you need (other than the washers and clip) is the small metal sleeve that fits in the grommet. Check your shift linkage to see if it's there. If not, you can make one out of copper tubing.
