´68 Form S BB inner f holes?
SSing
upland, sweden
Whant to get this correct before final finish.
Only ´68 Formula S 383 Barracuda´s is of interest.
Marked holes in picture ( passenger side) is for sheet metal screws and looks to be from factory.
I´m turning car into a Base model, or with nothing extra or options from factory if you understand what I´m trying to say.
I´m thinking all bodies have these holes, needed or not for the cars particular application?
So, should I leave holes??
Two holes in line with shock absorber mount, and one hole 7 1/2" forward.
Second picture here passenger side, (radiator support left ) is of a, what looks to be drilled hole, for a 3/8 screw or something.
Guess nothing from factory was bolted here? But this is my question. Weld shut or leave?
What do you say?
Thank you for taking the time.
AC mounting holes for the receiver dryer bottle and hose mounts?
Holes are not drilled if no A/C installed in car.
I would say weld shut if not going to be used.
