*moparguyrr69*
Member
440 engine, 456 with 8 ¾ rear end, 4-wheel disc brakes, new front & rear tires, new TrickFlow intake, 4 barrel Holly carb, 727 with reverse shift valve body, Hays clutch discs, trans brake, Champion all aluminum radiator, original glass, steel deck lid, fiberglass lift off hood. Solid 11 second car. Have many time slips from Dragway 42, West Salem, OH and Summit Motorsports Raceway, Norwalk, OH showing good run times. No title – Bill of Sale will be provided. $20,000 neg.
Car belonged to my late husband, Dave Goodrich, co-founder and President of Mid-Ohio Mopars.
Call or Text: 330-464-4322 (Steve) or 330-464-6612 (Carol)
HAVE RECEIPTS FOR THE FOLLOWING ITEMS:
- Moroso DS-2 Front Drag Tires -26.0 x 4.5 -15 (2)
- Mickey Thompson ET Rear Drag Slick -31.0 x13.0-15 (2)
- Right Stuff Mopar 8.75 & Dana 60 Rear Disc Conversion without Parking Brake
- Trickflow Intake Manifold, Track Heat, Aluminum, Single Plane, High Rise, Square Bore, for Chrysler 440 engine
- Champion Cooling Systems All-aluminum Radiator
- Velocity Stack Air Cleaner with 5 1/8’ Carb Neck
- Hays 40-220 Clutch Discs
- COMP Cams Steel Valve Locks & COMP Cams Valve Springs
- Auto Meter Ultra-Lite Fuel Pressure Guage 2 -1/16”
- JEGS 2-Port Pressure Regulator 5-12 PSI Outlet Pressure Guage
- JEGS Mechanical Guage Hose Kit – 4AN Braided Stainless Steel Hose
- JEGS 8mm Coil wire Kit Red Hot Power Wire (3 feet)
- Holley Standard Main Jet 84 Hole size .099”
- Holley Standard Main Jet 80 Hole size .0890”
- Holley Standard Main Jet 81 Hole size .0920”
- Holley Standard Main Jet 85 Hole size .0985”
- Thermo Tec Header Wrap Kit
- Hooker Headers Exhaust Gasket 383-440 V8 Engines
- TrickFlow Engine Oil Supplements
