[WANTED] 10" Front brake drum or drums, with out or with hub
hoop
Kentucky 40862
I'm needing passage side front brake drum for a 72 Dart, but if you have a set, I'll take both, if you have drum & hub steel together that would be good!
Max Dia. 10.090
Loc. Partridge, Ky
Looking for ones just like mine with inside lip the same!
I have some spare hubs--will have to double check on the mounting holes if you need, Lawrence
I'm needing the right drum because something happen on mine, just sead with hub bacause if someone has stock Mopar ones steel swagged together, that would be better for me, but if not that's ok!
I have the Brake Drums Brand New -- But No Hubs ---
Traditionally, the Hubs have to be re-used.........
Is the inside lip same as mine. most new ones you get online today they don't make the lip the same?...
but use to when you could get them at the auto parts they would give ya just what you need!
got factory ones 50. set plus shipping
Got one drum, but it did not work out for me, it resurfaced thicker on one side for some reason, so steel looking for a used drum!... only message me if you can send pics!
I have what you need. I haven't pulled the drums off yet. I can send pictures. I can machine these at my place of work and also measure them. PM me if interested. Thanks, Paul.
I have a complete set I just took off my Demon that look new with no rust and little wear complete with brake shoes. The Demon had been restored when I got it and was driven very little. These are ready to bolt on as is. I am installing a disc brake kit on the car now. I would take $100 plus shipping. I could get pictures to you later this evening if interested,
can you post a picture of the back side of the mounting area of the drum-- I have 2 styles of 10" sbp brake drums in my shed-- neither is on a hub-- also what diameter is the rear of your hub-- there are 2 sizes of these, Lawrence
