[WANTED] 10 inch AFB Air Cleaner Base Plate
FJRdoc
Brownstown, PA
I'm looking for a 10 inch base plate to fit the air cleaner on my brothers 273 2 barrel air cleaner. We purchased a 4 barrel intake and need a base that will fit an AFB.
Located 17543
To clarify, do you need the base from an AFB with a 4 11/16" flange? Better check your carb number to verify, and check the throat size! The book lists a 4119, 4120, 4121 and 4122 for 1966, and 4294 and 4295 for 1967! Not sure if the 67's had the 4 11/16" throat size but I know the 66's did! Here's a pic of a 66 unit, measures just over 4 5/8"!
Geof...indeed '67 AFB had the smaller air horn size. As there was no 273-4bbl engine in '68, I think that changed in '68 when they went to the AVS-style carb for the then-new 340.
FJRdoc....you could just buy a small aftermarket air cleaner assembly and just use the base under the top housing. The filter is shallow enough to allow the base to disappear up into the housing....no one will see it. Also, if you do have the small air horn carb, you can buy a plastic adapter to fit the larger base to the smaller carb.
I'm looking for a 4295 AFB for the conversion so the base will need to be 4 5/8". bThanks for the tip on the aftermarket air cleaner. I'll check around on Amazon or Ebay.
My scenario...273 4bl. Original 4295s carb. Orig chrome commando air cleaner. We put new Eddy 1406 on and the base plate didnt fit. Dad made an adapter outta plain house hold duct work. Worked great. Than I replaced the adapter by buying a swap meet Moroso base plate and Mcgyver'd it to work.
It depends on whether you will stick with the 4295 or not? I can get pics later if u want.
I have the original base for the 273 AFB. PM me.
