11 3/4 caliper mounting brackets (Cordoba)
rudmover
Hey FABO I"ve decided to try and find some of these preferabley the pin type I have cash anybody got some? I'll throw in the 11" ones I've got as part trade or just cash whatever suits. Please PM me if you can help a brotha out.
any suggestions on where to look? I'd like to move forward on the front end but I'm stuck on ordering rotors. I'd go junkyard scavaging but nothins close.
Are you sure that 11 3/4 is correct? I have a set from a 76 Cordoba with a 400 and the rotors were 10 3/4.
yeah I'm sure, I think a lot of doba's had the smaller rotor as well, I believe the caliper mounting brackets look the same but have a slightly different spacing allowing the bigger diameter rotor. they also came on several different land yachts.
They used both 11.75" and 10.87" rotors on Cordoba's the way to tell the difference is measure the bolt hole on the bracket's 3.5" bolt hole to bolt hole and 10.87" bracket is 3.12" b,h,tob,h,. I think I have one set left If you would like them. They are already bead blasted and painted $75 plus ship, just let me know.
recieved the caliper mounts today, super clean they look like NOS. Super fast shipping f8valiant is a great seller I'd buy from him again in a second.
