I’m posting this for a friend. It’s a new 11” Mopar Performance torque converter P/N P4876876 for the 1967-1990 non lockup 904 transmissions. This convertor was supposed to go into his early 1967 Barracuda 273 a while back, but the rear of the crank is the earlier shallow design so the converter crank hub wasn’t compatible. From what I understand the owner did, or had some work done on the hub to get it to work but didn’t finish the job so the hub needs to be finished to put it back to the later crank hub design as seen in the pic. Looking inside the trans end of this converter, it doesn’t look like any fluid was even put in. According to the MP catalog, this is designed with a 2250-2350 stall speed and used with a small block for general bracket racing and of course street action. I would like to get $50.00 for the converter plus the shipping.
Ken
Edison, NJ
Ken
Edison, NJ
