racerjoe
That's it! Thanks!
Based on what I'm seeing, I have better camber gain than the FMJ spindle. Now to calculate the roll center and hope it is better too...
That's it! Thanks!
I'm waiting for new lower bumps to come in before I have a real measurement. I'll have them touch the LCA at 2", but I'm sure they will compress enough to get another 1/2" at the wheel.re the suspension travel.... if your total will be 4" you should have 'about' 2 1/2" compression and 1 1/2" extension. so at ride height the suspension should be compressed roughly 1/3. this is standard practice for suspension setup. you probably already knew but you mentioned 2" up and 2" down so.......
neil.
I took several measurements with the suspension hanging on the ride height simulators Denny sends with the kit. They may not be dead nuts exact to my ride height, but its very close. I used the suspension calculator online to determine the roll center. There are some measurements that are difficult to get exact, but I messed with the numbers to see what changes it made. Some measurements made drastic changes while others did very little. The calculator outputs the tire camber, UCA and LCA angles. The results are damn near the same as what I measured, maybe just a tenth or so off. Either way, this looks fairly promising
I messed with it but not with as much precision as this time and it was 4" below the ground. I believe this was due to the UCA and LCA angles never intersecting. I don't quite understand the math behind that. Picture the LCA near level and the UCA pointing to the sky.I wonder what results you would get with the original BJ's.
This is very true.Something to keep in mind is that the BBD article doesn't talk about what ride height they measured the roll center at. Or at least as far as I can tell they didn't, maybe I missed it.
The article is pretty old, so I wouldn't be surprised if it was at a stock ride height. So, while they list a roll center, I would bet it isn't much use comparing them.
Not that you said you were, just an observation.
Also, I wonder how camber gain is affected by initial camber. They started with zero camber and it seems like the norm now is a half to one degree negative chamber for street cars.
This is very true.
I don't think static camber changes camber gain by any measurable amount. Obviously, more static negative camber shortens the UCA, but it is such a small amount, I doubt it is even measurable. My static is currently 1.7-1.8. I just started from zero to make it easier to understand.
If the roll center adjustment works as I anticipate, the current bar may be fine. Now that I have a little education on the topic, I think a bigger bar would have been a band aid to the real problem. If the problem is fixed, I won't need the band aid.now that we know what configuration it likes, I'll see about a larger diameter version. Are you thinking 1-1/8" solid or 1-1/4"?
To be fair, I've never seen Denny claim his kits offer better handling. That's kinda where I come in. Also, Denny doesn't force you to a specific spindle like some others do.I've always wondered what the mod did when Shelby lowered the UCA mount on the GT350 1". After all this, makes sense that he was getting the UCA sloped down towards the center of the car and changing the roll center. Cool.
Have to admit that I am a little disappointed with the COC claim that they handle better if the suspension geometry has the UCA's sloping down from the center of the car and the roll center underground.
@HemiDenny, seems like you have a "Super Slammer" kit or something? Does that move the k-frame and LCA up on the chassis, thereby raising the top of the spindle in relation to the UCA chassis mount?
I know QA1 is claiming improved handling and I'd really love for someone to take measurements so we can all learn.
Any Mustang 2 spindle will work on the HDK. However, I think the new ride tech spindle for chevelles will work. I found a steering arm that will provide the same steering angle as the M2. It would just be a matter of using the correct ball joints. The best part about the HDK is the adjustability and adaptability.Wasn't really calling Denny out on that, more of a general statement.
What other options are there for spindles with the HDK?
QA1 also uses M2 "style" spindles which I am betting results in a less that perfect UCA arrangement. Maybe they ship with an extended UBJ like you put in? Betting not though. Sorry, but feels like bad advertising rather than truth to me.
I really do think that the mindset for most is that a COC is needed to make an old car handle all because a Chevy really does need a new front suspension design to make it handle. And thus all makes need one because, like, Chevy is the best so if they need it so do we. Duh.
Tim is correct, HDK never claims they make the cars handle better.....I will however claim that the car will drive a whole lot different.
Dropping a few pounds with the ability to (easily) be more aggressive on the the alignment specs to match our modern tires is the name of the game. Add the additional room afforded by the elimination the OEM steering and torsion bars that allow for easier powertrain transplants and it is a win / win for us Mopar hot rodders.
Definitely not for everyone, especially those that want to keep their OEM ride.
For the record......Tim has an off the shelf / standard HDK package, not a "Slammer" or "Super Slammer" . Those packages were built for specific customers that wanted to lower the body to the extent they required extensive fabrication like raising the transmission tunnel and the OEM inner fenders. And yes, in those versions, as the the body drops, the K frame and its pivot points are raised. On most of the "slammer" builds standard length upper ball joints were used.
I am grateful for Tims input and glad to reciprocate with HDK "help" wherever possible.
If a GM spindle will work, a whole new realm of brake options open up.
I didn't try the ride tech spindle. I was leaning that way until I found the 2" long ball joint. I don't see any reason why it wouldn't work. They don't publish the ball joint taper and I found conflicting information on what Chevelles actually had. I would have called them to get more info before moving in that direction. What I have found is the circle track racers have gone through all of this and have many parts to modify control arm angles and GM spindle steering arms. The great thing about the HDK having screw in ball joints for both upper and lower is pretty much anything goes if you have enough tenacity to figure it out. Perhaps a GM spindle is the way to go since there are many options in heights and brakes. Again, this is all speculation that it will work, but I don't see any reason why it wouldn't.So you didn't try the ride tech spindle, right? Would be interesting to see how that all works. Did that spindle accept the wheel bearing you are already running?
The QA1 kit start with M2 spindle but they modify the steering arm. "QA1 spindles start as Mustang II components and have modified steering arms. Standard Mustang II spindles cannot be used."
Dion, you can go back and see where I mentioned the car felt better. It really is hard to explain, but it felt better right out the box from Denny. Perhaps its just the steering since there's no dead spot, or maybe it just well built chromoly tubing not flexing like a 50 year old stamped steel K-member and LCAs. I can't pin point exactly what it is. For the regular guy driving to the local cruise night or ice cream shop, he will interpret this as "handling better." But does that same guy even know what type of suspension geometry offers superior handling? I doubt it.Sorry Denny, but I've got to say that feels like "politician speak" to me. Drive different?
