12 volt vacuum pump amp draw question
22dog22
northampton ,pa
i have this 12 volt vacuum pump hooked up, the directions state to use a 10 am fuse, if I hook up the pump to the brake booster it blows a 10 fuse, if I do not hook the vacuum hose to the booster it does not blow the 10 amp fuse, it seems when I put a load on the pump it blows the fuse could it be under fused ? [ need higher amp fuse] when I go on the internet I see other vacuum pumps that look like mine and they say to use a 20-30 amp fuse what are your thoughts ?? not sure how to measure the amp draw when the pump is under the load
I'm with Kit/ Dave but if the instructions are clear and there is nothing else on the 10A fuse, I'd suspect the pump is bad
