ericp2733
New Member
This kit is a never used rear Baer brake kit that fits axle standoffs of 2.25-2.6" so this kit can be used with all 8 3/4 and Dana 60 rear ends I believe.
The kit comes with 13" two piece rotors ,big single piston PBR calipers, master cylinder, proportional valve as well as all the cables brackets and hardware to install. The full ebrake setup is included as well. This is an older kit so it's hard to find info on it but the original part number is 1142021 if you want to try
I'm located in Austin Texas if your wanting to pick up, if you want it shipped anywhere in the continental us I assume it will be around $40.
I'm Asking $600 for the kit.
Let me know if you have any more questions about the kit.
Eric
Eric
