[WANTED] 14 inch 5 x 4 1/2 Disk brake Steel rims.
Arron tate
T B L
USA
Looking for Mopar steel rims to complete a project.
They need to be disk brake type.
14"
5 x 4 1/2
4 1/2 bead to bead
2 3/4 center hole.
3 3/4 offset
4 hump cap retainer
See attached pictures
Thanks
Edited...SORRY.... I just realized you are looking for LBP wheels
I have a single wheel with those dimensions if you still need it.
Ken
Edison, NJ
Ken
Edison, NJ
Would it be possible to take a pix of the front, back, and bead area ?
Just want to confirm it is the same as what I have.
Thanks in advance
Here are some pics. The center hole measures just about 2.75". Unfortunately the tire is still mounted so I'm not able to get the pic of the bead.
Ken
Thanks for the pictures.
Can you please check and confirm that the 4 hub cap bumps (humps) are as follows.
2 of them directly across from each other should be 8 3/4
2 of them directly across from each other should be 8 7/8
The back space should be 3 3/4 (back of rim 5 bolt flange to the most outer of the back side of the rim).
Thanks
Those are the dimensions that I just measured.
Ok
Ok,
What are you asking for the rim and tire (unless you are going to dismount it)
Just as a note the rim has one extra hole by the 5 lug mounting flange that my set does not have.
Thanks
PM sent.
I did notice that extra hole in my rim. Not sure what that's all about. The hub cap covers it though.
