[WANTED] 14x5 1/2 steel stock wheels
rlcbit
Paducah. KY.
Hi looking to buy 14" 5 1/2 stock wheels small bolt pattern . Like the ones that came on 67- 69. A-body's GTS . Will buy four sets. Sixteen wheels. Thanks
Thay are rally wheels ? I need wheels that I can put hubcaps on. No rally wheels. Thanks
he is looking for the 5 1/2 " wide wheel used mostly on performance versions of the a body-- swinger, gts .etc
the 5.5 has a deeper dish to it, the wheel on the right is 5.5 the one with the tire is 4.5"
Lawrence
I have a set of 14x5.5" ill sell you! I'm heading up right now to break the tires off of them! PM with your email if you'd like to see them! They came from a 71 Dart! Geof
I have 4 off my Gts and might have another 4 of my GT all are sb pattern rims. Let me know if you want the one set or two and I will verify the second set are the deep style they should be
