15” limited choices: Cooper Cobra vs Mastercraft Avenger vs BFG Radial T/A vs ?
Tires and Wheels (Mopar Hubcaps Too)
Which currently available 15” Non-drag radials would you buy?
  1. BF Goodrich Radial T/A
    14 vote(s)
    35.0%
  2. Mastercraft Avenger GT
    2 vote(s)
    5.0%
  3. Cooper Cobra
    20 vote(s)
    50.0%
  4. Other (state in a post)
    2 vote(s)
    5.0%
  5. Drive around on four drag radials
    1 vote(s)
    2.5%
  6. walk instead
    1 vote(s)
    2.5%
  1. MRGTX
    MRGTX Well-Known Member
    1,891
    707
    Sep 24, 2007
    CT, USA
    Local Time:
    3:34 AM
    Does anyone have experience comparing these tires? Which is the best of the bunch...or the least terrible of the bunch?
    The problem that I’m finding is the lack of tire choices and worse still, a tire that’s available in 225-235/60/15 and 255-275/60/15. I would go with skinnier tires all around if it meant that I could find an actual summer compound tire. Still committed to 15” wheels, still need the rears to be 26” or so.
    Any advice would be welcome.
    • Agree Agree x 1
    • 318willrun
      318willrun Utube channel 318willrun
      14,599
      15269
      Sep 13, 2013
      I'm here
      Local Time:
      3:34 AM
      I've always had good luck with cooper cobras. Not that the others aren't any good or anything.
      • Agree Agree x 1
      • QuickDart360
        QuickDart360 Well-Known Member
        1,150
        406
        Apr 5, 2014
        San Antonio
        Local Time:
        3:34 AM
        I came across some hankook kinergy tires on ebay. They are available in 275 60 15 size. I have heard good remarks about this brand. May be another option to consider. 225 65 15 is also available for the fronts.
        • Like Like x 1
        • Thanks! Thanks! x 1
        • QuickDart360
          1,150
          406
          Apr 5, 2014
          San Antonio
          Local Time:
          3:34 AM
          215 65 15 was what I meant for fronts.
        • MRGTX
          1,891
          707
          Sep 24, 2007
          CT, USA
          Local Time:
          3:34 AM
          Good call there. This was one of the models suggested by my local tire dealer but it looks like something you might find on a Prius. Has anyone tried out these Kinergy ST?
        • Garrett Ellison
          Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
          2,698
          2117
          Jan 1, 2018
          Southwest VA
          Local Time:
          4:34 AM
          Why so wide on the fronts? What vehicle and what wheels are you running on it?
        • MRGTX
          1,891
          707
          Sep 24, 2007
          CT, USA
          Local Time:
          3:34 AM
          this is for a Dart Sport...
          Are 225s wide?
          I want as much rubber as possible on each wheel.
          • Like Like x 2
          • Garrett Ellison
            2,698
            2117
            Jan 1, 2018
            Southwest VA
            Local Time:
            4:34 AM
            They are to me, well at least in the front, anyway. Probably a little too much "all about the go, not about the whoa" mentality on my part. :lol:
            • Agree Agree x 2
            • QuickDart360
              1,150
              406
              Apr 5, 2014
              San Antonio
              Local Time:
              3:34 AM
              I have 215 65 15 on my fronts and are not so wide. 26" diameter. Car is a dodge dart sport. 15x6 and 4" backspace rallys.
              • Agree Agree x 1
              • Slantsix64
                Slantsix64 Well-Known Member
                2,451
                913
                May 11, 2014
                SGV
                Local Time:
                3:34 AM
                Front 225 60 15x6 and rear 255 60 15x7 are a good combo my brother has that set up.
                • Like Like x 1
                • A56
                  A56 MoParAffliction FABO Gold Member
                  1,027
                  894
                  Jun 24, 2014
                  White Oak, N.C.
                  Local Time:
                  2:34 AM
                  Nah, I have 235-60 14's on the front and 245-60 14's on the rear of my 69 cuda. All four wheels are 14x7 Indy slots
                  • Like Like x 2
                  • 66fs
                    66fs FABO Gold Member FABO Gold Member
                    4,685
                    1409
                    Sep 9, 2009
                    Greenwood, South Carolina
                    Local Time:
                    4:34 AM
                    I usually go by The highest speed rating first, wear second. I like to be 300 or lower for wear.
                  • 72bluNblu
                    72bluNblu FABO Gold Member FABO Gold Member
                    10,674
                    5110
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    1:34 AM
                    225's are definitely NOT wide. Maybe compared to stock, but not by any modern standard.
                    When I put tires on the 15x7" cop wheels I had on my Duster for a bit I was able to run 225/60/15's in a Falken Ziex, which were decent. But it looks like even in the few years since I bought those the selection has gotten even worse for 15's.
                    Out of all of them I like the Cooper Cobra's the best. They all have the same traction rating (A), but the Hankook Kinergy have a temp rating of A while all the other are "B", which means the tire temperatures are capable of 115+ mph. The B rating means 100-115 is all you get before tire temperatures climb outside of best performance temps. The Kinergy have a MUCH higher treadware rating though at 680. That number is a manufacturer supplied number though. The Coopers are a 440 and the T/A's are allegedly a 400, but after a couple years the T/A's are hockey pucks so I wouldn't trust the 400 number much. The T/A's also have a lower speed rating at "S", the Cooper's and Kintergy's are both "T" rated.
                    You can also get a Mickey Thompson Sportsman S/T a 235/60/15 and either a 255/60/15 or 275/60/15. But it has similar numbers, 440 treadwear, "A" traction and "B" temp ratings.
                    You can look up the definitions of all the traction, temp and treadwear ratings here too https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=48
                    Which you can't get in a DOT legal, street going, non-drag radial or tire for a 15" rim anymore. Which is one of the reasons I stopped running 15" rims on the street.
                    • Like Like x 1
                    • Mike69cuda
                      Mike69cuda 64 is the new 17 FABO Gold Member
                      1,495
                      1111
                      Jan 2, 2018
                      Overland Park Kansas
                      Local Time:
                      3:34 AM
                      Cobras are good. BFG figured out they are one of the last players in these tire sizes and near doubled their prices.
                      • Like Like x 1
                      • Agree Agree x 1
                      • AJ/FormS
                        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                        18,265
                        6496
                        Jan 19, 2014
                        South-Central Manitoba,Canada, 900ftelevation
                        Local Time:
                        3:34 AM
                        I have experience with both, since 2000
                        On the back;
                        Early on, I ran some generic 245s in the back, that was just ignorance on my part, I had no idea I was building a 400hp 367. Those went bald PDQ, and next I tried 275/50-15 BFGs, then 275/60-15BFGs , then finally I moved the springs and installed 295/50-15 Cobras. When those went bald, back to the BFGS.
                        So now, I think the Cobras has slightly better traction in the first summer. During the second they were about same. But by the third summer the BFGs were so hard as to be skateboards, also called "hockey-pucks"; And the Cobras were bald. I ran the BFGs out cuz they were predictable, and sliding was becoming a way of life, and I grew accustomed to it, and liked it. After that, I got more BFGs and then my Tire Shop, seeing how I was killing tires, had brought in another set (I love those guys) in anticipation of my coming around,lol. But I fooled them. I got older, and wasn't cooking them all the time. So the TireShop offered them to me, just to reduce their inventory. Made me a heckuva deal, so I brought them home and they are still in storage, lo these many years later.lol.
                        IMO, the Coopers look slightly better, and ,size for size,might be slightly better in the second summer;as compared to BFGs. But the Coopers are bald in less than half the time.
                        As for the 235/60-14 fronts, again the Coopers win for looks and second-summer traction; but the BFGs outlast them ~2:1, but are skating towards the end of the second summer. Which I also found to be fun. I just adjusted my driving style and picked my corners more carefully, often running recon laps.
                        • Like Like x 2
                        • MRGTX
                          1,891
                          707
                          Sep 24, 2007
                          CT, USA
                          Local Time:
                          3:34 AM
                          I didn’t think so either. I only went that skinny because I made the best out of the wheel I wanted rather than approaching this from a more rational perspective.
                          FWIW I have 285s on the front of the daily driver and those aren’t even as much as I would prefer.
                          I had a funny (to me) conversation with the guy at Town Fair Tire (a chain in New England) today. I asked if they carried Avon tires. He proptly said yes, they can get any tire.
                          I said “great! I would like to order a set of Avon CR6ZZ.” Pause...pause...pause...“we can’t get those.” Lol yeah, of course not.
                        • 66fs
                          4,685
                          1409
                          Sep 9, 2009
                          Local Time:
                          4:34 AM
                        • dartfreak75
                          dartfreak75 Restore it, Dont part it! FABO Gold Member
                          7,481
                          5237
                          Aug 10, 2011
                          Virginia
                          Local Time:
                          4:34 AM
                          The coopers in that same size is what I'm going with. I'm gonna run 225 -14 on the front tho. Just because I only have 2 15 inch rims
                        • YY1
                          YY1 Well-Known Member
                          6,711
                          2519
                          Oct 11, 2011
                          FL
                          Local Time:
                          4:34 AM
                          I've been a cooper user for years but...
                          The last pair I bought were terrible to balance.
                          4oz on a rim that only took .75 with the previous cooper.
                          The other one took 2.5 on a rim that only needed .25 before.
                          Coopers and the Avengers have better numbers than the Coker made BFG.
                          If you don't need RWL, there are dozens if not hundreds more choices.
                          Hankook has good tires in RWL even.
                          Kumo has good tires and used to have odd sizes.
                          Nitto has good performance tires and drag radials, both well respected.
                          • Agree Agree x 1
                          • toolmanmike
                            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                            49,532
                            34331
                            Jan 18, 2006
                            Iowa
                            Local Time:
                            3:34 AM
                            I bought Coopers for my 66 and BFG's for my Swinger. 255/60-15 BFG's had discoloring raised white letter issues for a long time. I would hope they got that fixed. Buy your tires from a local dealer in case you need an adjustment. I bought mine from Summit and were told by local dealers to "take them back to where you bought them" when I had a issue.
                            • Like Like x 1
                            • A56
                              1,027
                              894
                              Jun 24, 2014
                              White Oak, N.C.
                              Local Time:
                              2:34 AM
                              I've mentioned it once I'll mention it again. Make sure that the dot on the tire lines up with the valve stem on the wheel. I learned this while working for Harley many moons ago where a balanced tire is critical. I took the four wheels that I had powder coated and my brand new tires to a "tire and oil change specialist" and had to have them break the bead and spin the tire to line up the dot and valve stem just as they were getting ready to balance the tire. Fact check me.
                              • Like Like x 1
                              • Dartnut
                                Dartnut Don't hate me because i'm beautiful
                                10,784
                                3124
                                Apr 19, 2007
                                Southern Alberta
                                Local Time:
                                2:34 AM
                                I've always liked the BFG Radial T/As.
                                I've had good luck with them for years, however, I don't use tires in general to their full potential anyway.........
                                • Like Like x 1
                                • Agree Agree x 1
                                • RustyRatRod
                                  RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                                  60,900
                                  32599
                                  Jun 7, 2010
                                  Georgia
                                  Local Time:
                                  4:34 AM
                                  • Like Like x 2
                                  • famous bob
                                    famous bob mopar misfit FABO Gold Member
                                    16,614
                                    6389
                                    Aug 14, 2011
                                    okla
                                    Local Time:
                                    3:34 AM
                                    Hankooks are about all we run now on our drivers , no problems , and the ride way better than goodyears that came out on the wifes escape and my 2014 ram .
                                    Also have them on the front of my 68 fastback.
                                    • Like Like x 1
                                    • Demonracer
                                      Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                                      3,310
                                      1292
                                      Jan 31, 2010
                                      Cleveland, Texas
                                      Local Time:
                                      3:34 AM
                                      The yellowing or browning of BFGs has been a problem for many years. Good old Blechwhite takes care of it temporarily, other than that they are decent tires.
