L leroy Well-Known Member Joined Feb 14, 2007 Messages 68 Reaction score 7 Jan 17, 2022 #1 can i install 16 inch sebring wheels on a 1964 valiant small bolt pattern....... safely
72bluNblu FABO Gold Member FABO Gold Member Joined Nov 28, 2008 Messages 15,582 Reaction score 10,086 Location NorCal Jan 17, 2022 #2 Safely? No. 5x100mm is not the same as 5x4”. The 5x100 pattern uses larger studs too. So yeah, you can bolt those wheels on. But you’re basically using the wrong pattern wheel with hogged out holes to make it fit. It’s a bad idea.
C ch1ll FABO Gold Member FABO Gold Member Joined Jun 12, 2009 Messages 2,888 Reaction score 2,664 Location Belgium,wi Jan 17, 2022 #3 Bad fit, 4” vs 3 15/16”.
L leroy Well-Known Member Joined Feb 14, 2007 Messages 68 Reaction score 7 Jan 18, 2022 #4 thanks, i was just wondering.....
