If you wanted to run a wider tire, the 17x9 option might work. You could put a 245/45 tire on it and end up about where mine run, and the offset should keep the wheel off the outer tie rod end. But their published backspacing doesn't makes sense to me, should be a little over 7" for that wheel so I would reach out and verify with them.
