grassy
I just discovered that when I went from front drum to disc on the '75 Duster that I had to move from SBP to LBP.
I had planned on moving to 15s in the back so I have a set of (aluminum ?) adapters to go to the LBP
I was reading the post of Snuffys Duster and he put 17 inch Magnum/300 rims on his car...I was kinda freaking out about the cost of new rims/tires until I remembered that I had a set of aluminum rims / tires off of a '07 Mustang GT. So I tried the fit and the adapter fits perfectly.
I did a search on this site and someone was putting a set of bullets on his car but the rear tires rubbed the springs so spacers were required. If I use adapters, that wll solve this problem. Correct ?
I also tried to find the offset on my mustang rims and I think it is 40mm offset.
Will these fit my car without mods to the fenders?
I am not in love with these rims but it will be a good stop gap measure until I can afford new ones.
Thanks
ian.
Thanks
ian.
