Hi group,
Is a T314-11B 26 tooth 3rd gear right for my 1969 - 2.65 ratio trans which calls for an aftermarket WT294-11C. I picked one up (T314-11B) and it looks identical to my OEM gear. Both are 26 tooth, same outside diameter, gear pitch looks identical and neither has the identifying grooves which is correct for my trans. It sure looks right but Im confused between the B and C designation although I know they are from different manufacturers. Any thoughts?
Thanks,
Vic
Thanks,
Vic
