18436572 T-Shirts
harrisonm
Topeka, KS
I was watching Engine masters the other day, and I saw a T shirt with 18436572 on it. I did a Google search and came up with a BUNCH of possibilities. Here is just one:
Had to wrap my head around BB as I know rotation is ccw.:wtf:
Thinking it could be that the distributor is dropped in on the passenger side of the cam for the big blocks causing it to rotate ccw, but yet the cylinders are all firing in the same order as the small blocks.
Just have to reverse the plug wires on the big block dist cap . . so to say . . .
Chev small block and Mopar small and big block.
If you translate the Ford firing order into the Mopar Chevy firing order it's the same thing it's just that they number their cylinders differently. And they are timing off what we would consider the number two cylinder.
