185/75R-14
I think I have a light truck tire version of that size. I'll have to check in the morning.
Edit: @dibbons , I have Grenlander (?) light truck 185x14, no aspect ratio listed (again, ?) but look to be 70 a.r. They are on my car trailer (can't mount any bigger/taller) and I have no complaints. Bought from a hole-in-the-wall tire shop in socal, run at 50lbs pressure with a car on the trailer.
Would probably work like iron on a car. I'd buy em again.
2nd edit: forgot to look to see where made. Confident it wasn't in the USA.
I had good luck with Vercelli tires, at tires-easy. they are sturdy,(max psi 44lbs) look nice and handle very well.
Made in Thailand.......
Be careful! Trailer tires are not built the same as a car tire. I would not use a trailer tire on a car. Trust me... I found out the hard way once :-(
No, mine are LT, light truck tires, that I use on the trailer. They last much better/longer than trailer tires.
