1962 Valiant heater control cable
38 Dodge
Biloxi MS
OK so I was replacing my heater control valve and the cable is froze up so I polaced it in a tub of PB Blaster and let it sit over night I got home today and started working the cable free. I got it moving pretty good and started to install it in the wagon. When I was installing the cable the end at the dash lever bent and broke so I guess it was not as free as I had thought. Anyway so know the question does anyone know where I can get a replacement cable? Does anyone know what year cables will interchange with my application?
Thanks
FABO
Make your own. It's perfectly standard bowden wire. Go to a lawnmower repair shop and pick up a throttle control cable. Cut to length, casing a few inches shorter than core, and bend/coil the ends of the core wire to suit.
Never thought of that I will go check that out tomorrow.
Thanks Dan you have pulled thru again
