[WANTED] 1965 Barracuda trunk/light rear panel sheet metal passenger side
Cars and Mopar Parts Wanted
Thread Status:
Not open for further replies due to lack of activity. Consider opening a new thread instead.
  1. Ed Ruhl
    Ed Ruhl Member
    9
    1
    Oct 19, 2019
    Farmington Hills Michigan
    Local Time:
    3:36 AM
    Contact Seller
    I had more body work done in my Barracuda than originally thought and need
    rear panel (or portion) with sheet metal for tail light / rear panel, RH including trunk gutter, lower right side.
    Thanks
    Ed
  2. 69FBCuda
    69FBCuda Life in the Fast Lane FABO Gold Member
    2,772
    1457
    Aug 28, 2014
    Florida
    Local Time:
    3:36 AM
    Hi Ed, can you add pictures of the exact areas that you need. I have the trunk gutter, sheet metal and tail light section.
  3. 69FBCuda
    2,772
    1457
    Aug 28, 2014
    Florida
    Local Time:
    3:36 AM
    What say ye ?
  4. Ed Ruhl
    Ed Ruhl Member
    9
    1
    Oct 19, 2019
    Local Time:
    3:36 AM
  5. 69FBCuda
    2,772
    1457
    Aug 28, 2014
    Florida
    Local Time:
    3:36 AM
    I'm sure there's better metal out there in the market as this does have some rust issues. There is red, blue and gray paint on these. You can see where I cut the trunk panel away from the corner and the pieces should match up going back together. If you are interested I can clean these up some and get better pictures, I can also cut them down to the the size you need to save on shipping. I would like $25 for the corner and $25 for the right end of the trunk panel(your measurement). From the horizontal corners just above where the bumper is are very solid. All plus shipping and any fees.
  6. 69FBCuda
    2,772
    1457
    Aug 28, 2014
    Florida
    Local Time:
    3:36 AM
    You can see the splice lines where
  7. Ed Ruhl
    Ed Ruhl Member
    9
    1
    Oct 19, 2019
    Local Time:
    3:36 AM
    Thanks 69FBCuda, I would like one that hasn't been cut up near the gutter if can't find I will contact you.
    Thanks
Thread Status:
